piston rings
Old Aug 6, 2008 | 09:10 PM
350rs's Avatar
March 2008 ROTM
Default piston rings
im gona replace the rings, what should i look for other than 60 over rings?
Old Aug 6, 2008 | 09:22 PM
350rs's Avatar
March 2008 ROTM
Default RE: piston rings
also, is there a way to tell what pistons i have? they are domed, but other than that i have no idea. i need to know.
Old Aug 8, 2008 | 02:37 AM
sewerrat's Avatar
Sometimes the brand will stamp the casting# on the inside skirt. Are you trying to figure out the dome size?
Old Aug 8, 2008 | 03:00 PM
350rs's Avatar
March 2008 ROTM
yea, that was my bad, they are actually dished. confusion on the deffintion between the two. but i still wanna know. ill look.
Old Aug 9, 2008 | 01:42 AM
sewerrat's Avatar
One easy way is to beg, borrow or steal a cc kit with the 100cc graduated cylinder. I bought my el-cheapo kit from summit. Follow the instructions that come with the kit and I'll tell you the cc's of your dish. Also, you may want to get an inside bore gauge just to see if you have a taper bore. Good luck 350.
Old Aug 9, 2008 | 09:31 AM
350rs's Avatar
March 2008 ROTM
yea i had planned on gettin a gauge. does it matter what brand or are they all about the same?
Old Aug 9, 2008 | 07:53 PM
Jr. Mechanic's Avatar
August 2009 ROTM
Just get a set of calipers.
Old Aug 10, 2008 | 02:12 AM
sewerrat's Avatar
ORIGINAL: 350rs
I'm sure the more expensive sets will outlast and hold their accuracy better. I bought the cheaper kit from summit. I don't build engines for a living but this cheap set has served me well. I'llcalibrate it to 4.000" with a micrometer and then run it through all the bores.It makes reading all eight cylin various locations a snap.It's not super accurate but it givesme an idea of a taper or oblong shape.Theset comes with smaller pinsso you canmeasuring the conrod bearing holes for stretch too.
mach2mack
May 13, 2012 09:47 AM
REN
Jul 8, 2010 11:32 PM
kyphur
Apr 13, 2010 10:30 AM
microkid
Dec 6, 2007 04:26 PM
Andross
Nov 13, 2006 09:55 PM
