Help where do these o-rings go?
Old May 12, 2012 | 08:51 PM
mach2mack's Avatar
Default Help where do these o-rings go?
Where do these 2 o rings that came in my timing cover gasket set go ?
Old May 12, 2012 | 08:58 PM
BasicConcepts's Avatar
Technical User
on either side of the waterpump shaft just keeps the shaft from rattling
Old May 12, 2012 | 10:17 PM
I put a light coating of grease on the splines of my water pump shaft, so it wouldn't be dry on dry metal to cause a rattle. So my o-rings holds in the grease and prevents rattles!
Old May 12, 2012 | 10:21 PM
Technical User
ohhh fancy
Old May 13, 2012 | 09:47 AM
mach2mack's Avatar
Thanks
REN
Jul 8, 2010 11:32 PM
350rs
Aug 10, 2008 02:12 AM
microkid
Dec 6, 2007 04:26 PM
ScottD
Aug 23, 2007 06:00 PM
Andross
Nov 13, 2006 09:55 PM
