Rotor spinner rings
Old Jul 8, 2010 | 08:16 PM
REN's Avatar
REN
Default Rotor spinner rings
Do stock rotors require spinner rings? Mine did not have any on when I replaced them. If so who might sell these?
Thanks
Old Jul 8, 2010 | 08:26 PM
not sure what your talking about but nothing called a spinning ring on mine.
Old Jul 8, 2010 | 08:35 PM
REN's Avatar
REN
i saw them on some aftermarket rotors they looked like a thin retaining ring over the wheel studs to keep the rotor from shifting, but I guess the lug nuts will do the same thing
Old Jul 8, 2010 | 08:56 PM
ok, yah the wheel holds the rotor in place. i have not seen them for the camaro,,, as far as that goes i havent seen them on any of the gm cars or trucks ive done brake jobs on. lol i work on my own vehicles and do a favor once in a while so my experiance with different setups is limited.
Old Jul 8, 2010 | 11:32 PM
I've had what you're talking about. They've been either like a star washer (sort of) or a spring washer that's a wedge fit onto one of the studs, and you have to snap or force it off to remove the rotor. It's there from the factory to keep the rotor in place during assembly. You don't need to put one back on, as the wheel holds everything in place.
mach2mack
May 13, 2012 09:47 AM
maudyZ28
Aug 12, 2008 03:32 PM
350rs
Aug 10, 2008 02:12 AM
microkid
Dec 6, 2007 04:26 PM
Andross
Nov 13, 2006 09:55 PM
