one wheel spinner
Old Aug 11, 2008 | 08:21 AM
maudyZ28's Avatar
Default one wheel spinner
my diff is really starting to do my head in, its a posi cause i put it in myself but if iboot it during a rh turn it only spins up the inside wheel so my big cloud of smoke dissapates i look daft as there is only one big line, WHY
any ideas ???
Old Aug 11, 2008 | 08:28 AM
Z28Reggie's Avatar
Default RE: one wheel spinner
Are you hanging the turn fast like 45 turn with all the weight to one side Prolly not it but i had a problem with that with my third gen
Old Aug 11, 2008 | 12:25 PM
Posi gone bad??
Old Aug 11, 2008 | 04:23 PM
Are you trying to do this while going thru a turn normally, or while slamming it thru the turns? Sounds like it could be a weight transfer/diff lock thing. I'm sure you know how limited slip works while going thru a turn. Do both wheels grab from a standing start though?
And if you make that type of driving a regular habit, you may wind up also looking "daft" once your rearend pukes.
And if you wouldn't mind posting your VIN # too? I want to add it to my growing list of which cars not to buy!
Old Aug 12, 2008 | 03:32 PM
maudyZ28's Avatar
been there done that already, if you dont practice things go bad when the **** hits the fan,
dont worry i live in uk so you wont every have to buy it.
with ref to post it locks up fine in wet but not in dry, from a bog both spin but up in top revs it seems to be right one only and right only when turning from start like you would to do doughnuts ( defo dont do those i must draqw a line) !!
REN
Jul 8, 2010 11:32 PM
