what should i do?
Old Aug 11, 2008 | 10:55 PM
z28rob18's Avatar
Default what should i do?
all the mods i already havr listed below wat do u guys think i should do next? id lik to get into the low 12s soon
Old Aug 11, 2008 | 11:03 PM
th3po1son's Avatar
Default RE: what should i do?
how much do you want to spend?
Old Aug 11, 2008 | 11:06 PM
z28rob18's Avatar
ill say for nw 2000 and i already hav a cam and intake in my room lol
Old Aug 11, 2008 | 11:11 PM
z28rob18's Avatar
o an would it be worth porting and polishing the heads over the winter if i was gonna tear it apart in summer to build a 383?
Old Aug 12, 2008 | 01:13 AM
95slvrZ28's Avatar
If you want to do a 383 build right you're going to need heads that have a substantial amount of flow over the stock heads. Look into AFR 210cc or bigger race heads to get the job done.
Old Aug 12, 2008 | 08:10 AM
z28rob18's Avatar
alright so i wouldnt beable to get the stock heads ported out enough?
Old Aug 12, 2008 | 09:00 AM
viciouZ's Avatar
Get a ring and pinion gearset. That will easily break you into the 12's if you are already running 13.1. Or slap on some drag radials. I guess it really depends on how serious you are. You could shed some weight (spare, jack, carpets, rear set, washer fluid, armrest stuff, glovebox crap, 1/2 tank of gas) and save 100lbs. Also, I'd take a look into replacing some suspension components. Not only does this make the car more responsive on the street, but will make it more pleasurable on the track as well. A new torque arm will help your launching.
Old Aug 12, 2008 | 09:10 AM
z28rob18's Avatar
i am kinda serious but im not takin the carpet and stuff out yet the suspension stuff should be covered after xmas i gave my gf a short list of things for my bday xmas and somtin else so after the holidays i should hav the suspension covered wit lcas adj panhard bar strut tower brace and subframe connectors and i wanna go wit a set of 4:10s but im worried about the rear givin out and if i gotta buy a rear thatll be lik all my money for awhile
Old Aug 12, 2008 | 09:47 AM
viciouZ's Avatar
Changing the ring and pinion isn't going to sacrifice your rear end. Keeping your foot in the gas on hard launches - that will destroy the stock rear end. The destruction occurs sooner when you roll on stickier rubber.
Old Aug 12, 2008 | 11:20 AM
z28rob18's Avatar
i no so makin thecar faster for the track would mean more of a chance that it goes bad
