Odd humming type noise
Old Jun 9, 2011 | 07:46 AM
  #21
djs383's Avatar
Originally Posted by carguy68ssrs
DID you try taking the fan belt off yet?
Pretty sure he's got electric fans.
Old Jun 9, 2011 | 11:34 AM
  #22
carguy68ssrs's Avatar
Let me REPHRASE,
Pull the serpentine belt off and see if the noise goes away.
Taking the belt off eleminates the alternator, ac clutch (if he has air ) Tensioner pulley, idler pulley, power steering pump, smog pump and water pump.
If no noise he can check for any play in pulleys on all the stuff that now have NO TENSION on them.
Lots of time it is idler pulley bearing or tensioner pulley bearing. If they wiggle any amount they need to be changed.
Old Jun 9, 2011 | 02:54 PM
  #23
jasunf's Avatar
Thanks for all the suggestions!
No the belts were recently put on I haven't tried to check any of those. There's 3 individual ones no serp belt I'll give those a once over though. I'll give that a shot to see if their components are to blame.
Looks like I have some fun times this weekend Thanks all!!
Old Jun 9, 2011 | 03:34 PM
  #24
I'm sorry, thought 87 had serp belt, geuss it started in 88.
Having v-belts makes it better cause you can just remove one at a time and run engine to check for noise.
Still check pulleys when the belts are off for any play in bearings.
When you have all the belts off you can hear all the other noises your engine makes that you can't hear with the belts and stuff spinning.
Good luck finding noise
Old Jun 9, 2011 | 03:38 PM
  #25
Forgot one thing, when you tighten belts, do not over tighten.
OVERTIGHTENING just puts extra load on bearings and wears them out faster.
SS_2000
Jan 4, 2011 11:47 AM
96zeetwentyeight
Dec 3, 2010 10:50 AM
19IroczCamaro87
82-92 V8 Tech
Aug 23, 2010 10:18 AM
SS_2000
LS Series Tech
Mar 26, 2010 08:31 AM
Chevykicksbut
Sep 20, 2009 03:14 PM
