Odd humming type noise
Old Jun 8, 2011 | 08:36 AM
djs383's Avatar
It could be the AIR injection lines have become loose and are vibrating, mine did that a few years ago it was cracked on the line that went to the cat....its just another thing to look at.
Old Jun 8, 2011 | 05:45 PM
microkid's Avatar
March 2011 ROTM
Technical User
if it has a high volume pump, im guessing the bypass valve was actuating. the listing for the mobil filter for the f-body is a small filter. i use the one for an early 90's 2wd truck, it holds about a quart of oil
Old Jun 8, 2011 | 06:07 PM
jasunf's Avatar
No good Changed oil filter and oil and it remains. Still only does it around 600 RPM only. When I get the RPMs up over 600 it goes away.
Nothing with the high flow oil pump at low RPMs?? I can't see anything loose
Old Jun 8, 2011 | 06:08 PM
jasunf's Avatar
Will check. Any location? I have to manuals but you may save me some time investigating where these lines run
Thanks!
Old Jun 8, 2011 | 06:21 PM
microkid's Avatar
March 2011 ROTM
Technical User
they run down the passenger side exhaust to the cat. did you check the shield for the convertor?
Old Jun 8, 2011 | 06:32 PM
jasunf's Avatar
Got it. Checked and that part seemed solid. I can't find any cracks in any hoses but the cars pretty hot right now I let it cool and check later.
I checked near the distributor area and the sound is strong there too. Its like its right behind the engine. Driving me crazy! And it surges between 400 and 600 RPMs back and forth like a vacuum problem of some sort
Perhaps I should install bigger speakers??
Old Jun 8, 2011 | 06:42 PM
microkid's Avatar
March 2011 ROTM
Technical User
remove the dizzy cap and check the rotor and shaft. could be a worn bushing inside and is making noise. check everything in that area. its not something i would ignore
Old Jun 8, 2011 | 10:13 PM
jasunf's Avatar
Would I feel the vibrations if it were or would it not be constant instead of coming and going? Like now I can't get the sound to come back. Arg
According to service history the cap and rotor were replaced:
From - Marine Chevrolet Cadillac on 7/31/2008
Mileage = 135,218
Description - Customer states that the vehicle will nto start. Replaced battery and battery tray. Vehicle would start but not run. Traced problem to mass
air flow sensor and electronic control module. Replaced both and tested ok.
1 Battery
1 tray
1 holddown
1 bolt
1 bolt
1 ECM Rem 3.670 194
1 MAF SENSO
Free diag
Recommend all fluids be changed. Several bulbs. Tail shaft seal. Break flush. Rear diff service.
Customer request BG cooling system service. Perform service by remoting rust, sludge, and scale.
Replace plugs and wires.
8x spark plugs
1x wires
Tune 8 cyl motor - replace cap and rotor
1x dis cap
1x dis roto
Old Jun 9, 2011 | 01:59 AM
carguy68ssrs's Avatar
DID you try taking the fan belt off yet?
Old Jun 9, 2011 | 07:45 AM
  #20
djs383's Avatar
The video is a little better than vauge, but it still may be those lines, there is a line that runs behind the distributor to connect to the drivers side manifold. It could be a couple things, you just have to go one step at a time.
