no start
Old Sep 1, 2009 | 08:43 PM
94z28chevy's Avatar
Default no start
i got my transmission in (th350) and took it around the block open headers (shorties) and wont got faster than 15 MPH not so happy about that and i just turned on my street and car dies and wont start up. starter wont do anything no sound so we pushed the car home and first we thought it was the starter i had an aftermarket one in so we put the stock one in turn the key the light dim but the samething as the aftermarket so i took both starters in to get tested both work great looked over the wireing there is no fuseable link and all the wireing is ok so i replaced the Ignition Module Control thats hooked to the steering collom same so i hooked up a push button swich still nothing WTF
Old Sep 1, 2009 | 09:12 PM
did u charge the battery up?
Old Sep 1, 2009 | 10:29 PM
94z28chevy's Avatar
yes i did and i have replaced the old one with a new one
Old Sep 1, 2009 | 11:33 PM
Running with the open shorties probably wasn't the best thing to do. You may have melted a wire in the starter circuit, among other things. I would check everything carefully.
As far as not being able to go any faster, I think your problem is that your computer is no longer getting a speed signal from the trans like it was from the 4L60E, unless you did some type of VSS conversion from the old trans to the new.
Go here: http://www.novak-adapt.com/knowledge/th700r4.htm and read the part about the Vehicle Speed Sensor (VSS).
Old Sep 2, 2009 | 09:59 AM
94z28chevy's Avatar
the trany is junk i took out the 700r4 and put in a th350 it wont shift into 3rd and slips really bad in 2nd so i need to get it rebuilt. but when i hooked up the push botton i ran new wires just in case that was the problem i ran a wire from my battery to the push botton to the coil on the starter
Old Sep 2, 2009 | 10:00 AM
94z28chevy's Avatar
i just notice that i forgot to say what year my camaro is its a 85 z28
Lakatrae
Mar 29, 2014 10:59 AM
rdb357
Mar 30, 2008 08:25 AM
JTyler
Aug 31, 2007 10:21 PM
coco
Aug 13, 2007 10:33 AM
