no OD or TCC lockup
Old Nov 2, 2010 | 08:54 PM
  #31
microkid's Avatar
March 2011 ROTM
Technical User
yea. still not sure if thats the issue. ill have to pull out my multimeter and do some testing to see if the solenoid works in the trans. if it does, ill just put a switch on it and do it myself
Old Nov 2, 2010 | 09:03 PM
  #32
switch on the wheel. that will make it a 5 speed, sure seems like it with mine. way more noticable with the stall and built trany.
Old Nov 2, 2010 | 09:20 PM
  #33
Handy dandy wiring info and stuff: http://www.hotrodhandbooks.com.au/eB...Line-11-5.html
Old Nov 4, 2010 | 08:17 PM
  #34
microkid's Avatar
March 2011 ROTM
Technical User
i did finally try to adjust the tv cable. the second one is of much better quality, however is bottomed out on the adjustment. since i messed up the old cable bracket thats on there, im going to have to get a new one to the adjuster stays firmly in place. there is one tpi car nearby that im going to try to get it from. if that doesnt fix the shifting issue, ill just oblong the holes and adjust it that way
camaro69, that link could be helpful. if i have to, i may just cut the tan wire and run it to a switch ground. it would be cool to be able to lock the tcc in second and third gear. i love engine braking
Old Nov 4, 2010 | 08:58 PM
  #35
If you do end up hot-wiring the t.c., just be careful not to go beating on the car through the gears with it locked up. The clutch inside the t.c. grabs like a conventional friction clutch, but it's not heavy duty to take low end torque, and you'll end up breaking it. That's why from the factory it's designed to lock in once you're cruising, and unlock while you're giving it heavier throttle.
Old Nov 5, 2010 | 08:10 PM
  #36
microkid's Avatar
March 2011 ROTM
Technical User
yea, i wouldnt do that. i know my honda that i used to have and my blazer will lock the tcc in third wot, darling's car i believe locks in third normal driving. but yea. if that doesnt do anything, i would be led to believe its the solenoid
Old Nov 5, 2010 | 09:48 PM
  #37
put about 3k into the trany and you could lock it up anytime.
Old Nov 5, 2010 | 10:01 PM
  #38
microkid's Avatar
March 2011 ROTM
Technical User
wont neglect do the same thing? if it ever goes, im gonna swap in a t56 magnum. it was rebuilt before i bought the car, so only about 10k miles on it, if it was even that much. i have the original receipt somewhere
Old Nov 5, 2010 | 11:50 PM
  #39
The tcc strength issue isn't with the trans, it's the torque converter itself. What kind are you running?
Old Nov 5, 2010 | 11:57 PM
  #40
" Power Raptor Lock-up " Fits 700R4 transmissions. This is a 10 inch converter with a 12 inch lock-up carbon fiber clutch rated up to 700 horse power. Can be ordered in stall speeds of 2000 to 4000 RPM. Lower 60 foot times and improved quarter mile times, an average of 1/2 second reduction! This torque converter has a torque multiplication rate of 2.5. The Ultimate Top of the Line Lock-Up Converter. Cost $585.00
