No heat 1989 rs 305 v8 tbi camaro
Man, your car's been hacked up. Here is a pic of my old 91. You can see the two heater hoses running along the valve cover, connecting to the heater core at the firewall. The third fatter hose that's connected to the valve and leading towards the inner fender runs up to the front and connects to the radiator.
man ........So i need to buy all new hoses and reconnect them to the heater core and radiator and that heater control valve .... should i be able to use the heater control valve that was in there ? ....or what should i do and what parts should i buy ? thanks for all your time and help on this
You might want to hook up the in and out hoses to the heater core, and run water from a garden hose through it. Then if it does turn out to be a leaker, you can still drive the car.
