no gauge lights
Old May 12, 2009 | 11:59 PM
NEVERLETITDIE's Avatar
Default no gauge lights
well i have a 89 camaro and all of a sudden the gauge lights stop working
checked around found that the fuse was blown. quick fix
i alsoo noticed that there was a arc on the tail fuse for the parking lights and it was the holder for the fuse wasnt making a good connection and i figure it blew the instrument panel fuse because they both run to the headlight/parking light switch anyways (back on track)
they worked for about 2 weeks and then they want out i replace the fuse but it will blow out instantly pretty much or last about a min. so its jus the istruament panel fuse that keeps blown now
you guys got any ideas wat i should look for?
ive looked around the fuse block for melted wires anything touching metal.. and such.
do you think its a bad switch?
Old May 13, 2009 | 12:07 AM
mtn_maro's Avatar
sounds like a short. follow your wires all the way up to the instrument panel connectors
timopajala
Mar 31, 2015 09:43 AM
mp734
Jul 3, 2014 07:40 PM
camaroxguy
Jan 10, 2012 05:43 PM
Camarokid94
Aug 23, 2011 08:23 PM
chrshadil
Dec 29, 2007 07:28 PM
