Need help, fuel pump problems
Old Jul 5, 2010 | 03:51 PM
cperkins614's Avatar
Default Need help, fuel pump problems
I Have a 92 Z28 350 TPI, I have put 2 new fuel pumps in an with no luck!! Car still don't fire up, Runs for a few seconds on startin fluid of course! I am Baffled!!! For Some reason Its Not pumpin any fuel to motor, not even through the filter!! ANY HELP OR SUGGESTIONS WOULD BE GREATLY APPRECIATED!! PLEASE HELP
Old Jul 5, 2010 | 07:17 PM
microkid's Avatar
March 2011 ROTM
Technical User
check the fuel pump relay and fuses
Old Jul 6, 2010 | 03:40 PM
i have replaced the relay an the fuse. I am stumped... I have also put new plugs, wires, distributor, rotor, control module, batter cables and still no firin up!!! Just Rotates... I keep messin with the timing, but i am really positive it is good.
Old Jul 6, 2010 | 06:53 PM
microkid's Avatar
March 2011 ROTM
Technical User
have you checked for power at the fuel pump while you had it out? connectors can go bad. also, when you turn the key on, do you hear the pump run? it should run for about 2-5 seconds when the key is turned on. there is also a fuel pump test pin on the aldl, but i dont know which one it is. try doing a search on fuel pump test or fuel pump aldl
Old Jul 7, 2010 | 07:07 PM
I Have Checked For the Pump to Kick On an Didn't Hear it so I changed the relay & fuse, Still nothing. But I will definately check for power, or for a test. Thanks!
What is the Pump Aldl??
Old Jul 8, 2010 | 07:56 PM
microkid's Avatar
March 2011 ROTM
Technical User
i meant for you to search that criteria. there is whats called the aldl, meaning assembly line diagnostic link. if for early on board diagnostics, and its located on the drivers side kick panel, near the fuse box. one of the pins supplies power to the fuel pump when a hot jumper wire is put into it, i just dont know which one it is.
Old Jul 8, 2010 | 09:54 PM
ok thanks for the Help, I should of tested it while i had it out!!! But guess thats what this site is for. lol I did a search last nite on testing fuel pumps came up with a few tests but none mentioned what you are sayin, i will look into it more, thanks!
Old Jul 9, 2010 | 01:06 AM
carguy68ssrs's Avatar
ALDL is right below steering column on your car,just to right of fuse box,you will be staring right at it,might have cover on it but I doubt it. Has place for 12 pins but not all are used. Top row probably has 5 pins, bottom row only 2 or 3. Haynes says G terminal should run pump, shows it as bottom left pin. Page 4B-3 in Haynes repair manual. I think all you guys should get manuals to help out, I have both Chilton and Haynes cause sometimes one shows more than the other. Chiltons didn't even talk about testing pump using ALDL
Old Jul 18, 2010 | 03:51 PM
Thanks For All Your Help!!! I DO Have a Haynes Manual, It Has Helped me Out alot!! I Will update as Soon As I Get It To Fire up an Run Again!!
kylet8020
82-92 V8 Tech
May 14, 2012 01:19 AM
JSchlenk91
Feb 29, 2012 09:47 PM
systemsmack
82-92 V6 Tech
Jul 10, 2007 08:40 PM
bubba747
May 7, 2007 11:38 PM
bubba747
Mar 27, 2007 06:00 PM
