AC Went Out....Help!!
Old Jul 13, 2010 | 04:55 PM
jcase350's Avatar
Default AC Went Out....Help!!
I have a 90 Camaro Iroc-z w/350. The AC went out on me today. It is not blowing any air at all...heat or AC. Are there any relays or anything else i need to check before i replace the blower motor? Thanks in advance!!
Old Jul 13, 2010 | 07:34 PM
carguy68ssrs's Avatar
easy to check motor. pull plug off motor and use jumper wire to apply power from positve side of battery to that plug on motor. If it doesn't spin,motor is bad
Old Jul 18, 2010 | 05:12 PM
jcase350's Avatar
Thought you guys might wanna know what happened. After some troubleshooting I found out the blower motor went out. Weird thing is it would come on every once in a while like nothin was wrong. Weird!! Thanks guys!
