got tach...what rpm for shift light?
Old Mar 19, 2009 | 03:24 PM
Saint Ebony's Avatar
Third Generation Moderator
March 2010 ROTM
Originally Posted by doug91rs
if u r on the street just let the automatic do the work but if u r lookin for a little better ET manualy shifting an auto is good. it depends if u have anything done to the motor if its stock you shouldnt let the rpms get too hight 5,500 to be safe since the 305 is making peak hp at that rpm there is no reason to let ur engine rev up any higher. but if u have a couple things on the motor such as a cam heads or intake it could really change the rpm band. is it stock?
Untrue. Shifting an automatic merely enables the higher gears. It doesn't shift into them.
When you shift an auto from 1 to 2, it doesn't shift the transmission into second gear. It allows the transmission to shift into second gear, what this means is that the transmission will shift when it's good and ready to shift, and the only thing you're doing is over-revving your engine and stressing your lower gears.
Furthermore, s stock 305 makes its peak power at 4400 rpm, not 5500.
Old Mar 24, 2009 | 06:37 PM
microkid's Avatar
March 2011 ROTM
Technical User
i second the previous post. i ran 3 tenths slower at the track when i shifted manually. i just kept it in 1st during burnout and stage, then pushed it to drive at 20 mph. it ran 15.204 @ 92.24 shifting auto and 15.523 @ 88.32 shifting manually at 5300-5500. stock 305 tpi, no muffler, air box mod, and 2 dead cylinders.
as for your tach, it sounds like its setup for a v6. check the instructions with the tach and set it to run for a v8
Old Mar 26, 2009 | 11:03 AM
1989_RALLYSPORT's Avatar
tach is set on v8
5500 rpm on stock is nearly 8800 on aftermarket.....the higher the rpm the more the tach is off by
01ss
Oct 21, 2012 09:34 AM
us63bravo
Jun 18, 2010 01:34 PM
lt4weeda
May 8, 2010 12:46 PM
marck
Aug 28, 2008 01:21 PM
microkid
Jan 8, 2007 07:14 PM
