Gear problem
Old Apr 2, 2007 | 03:38 PM
Gordon24Camaro's Avatar
Default Gear problem
ok, i press the clutch and the car wont go into gear, if i try going to 1st or rev., it grinds, but on the other gears it just wont go in. So i have to start the car on 1st so it can finally go, and 1/2 the time the car will shift to 2nd and on. The clutch pedal feels really weak too. I checked the fluids and their all up. After somehow driving the car. I turn it off and a few hours later turn it back on to go and it goes fine, except the clutch grabs the trans. way to early as i lif tthe clutch causing me to be real slow and carfeull as i drop the clutch so i wont stall out, but shifting to the other gears is fine.
Old Apr 2, 2007 | 04:58 PM
1985RS's Avatar
Default RE: Gear problem
I'd say that your clutch is worn out, maybe check that out, and if the clutch is fine it may be the slave cylinder or release bearing
Old Apr 2, 2007 | 08:32 PM
coprunr's Avatar
sounds like the slave cylinder or master cylinder is leaking interanlly ,also the pressure platecould beworn out not allowing the clutch to fully release (release fingers on the plate weak). if that's the case it's time for a clutch/pressure plate /release bearing and possilbly flywheel (if yours can't be resurfaced). get a friend to push the clutch petal while you look at the slave cylinder on the side of the trans. if the cylinder is moving quite a bit (i mean and inch or more) , sounds like you need the clutch kit , if it doesn't move very much (or not at all) you need a master cylinder and slave cylinder (clutch master not brake master).
Old Apr 3, 2007 | 12:28 AM
350rs's Avatar
March 2008 ROTM
i had a smiliar problem. Strangest thing for me though, Bellhousing was comming off the block... Check those bolts, make sure its good and tight. Me? i always check cheep and easy stuff first before assumeing the worst, its easier on the emotions too. lol.
Old Apr 3, 2007 | 12:34 AM
MadMikeZ28's Avatar
ORIGINAL: 350rs
But really. Check the clutch fluid. dont just look at the resivour because there may be a ....thingy ( i am at a loss for the word!) in it and it will look dark and make you think there is fluid in there. Also look at the slave and make sure its bolted up tight still. And while your there check the bell house bolts.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
mjstempky
Aug 29, 2010 01:01 PM
purpl96
May 26, 2008 09:30 PM
purpl96
May 3, 2008 11:21 PM
94Ztwo8
Jun 10, 2007 10:48 AM
