4th gear problem
Old May 3, 2008 | 08:11 PM
purpl96's Avatar
Default 4th gear problem
I just bought a 93 Z28 today with a 6spd. I got it so cheap that I didn't bother looking at the flaws more then once. Heres the problem. Occassionally when I shift it into 4th the stick starts viberating in place as if it wasn't in it's proper spot. So all I do is re-apply the clutch and pull it even harder to ensure it's in the gear fully and it works like a charm. I at first thought it was my fault for not putting it in gear all the way but it doesn't do it in any other gear, and plus I shift kind of hard anyway so I don't see that it could be my fault. This is my first manual transmission and I was wondering if this was a sign of 4th gear going out. Can anyone help?
Old May 3, 2008 | 11:21 PM
qmracer's Avatar
Default RE: 4th gear problem
I have a similar problem, if you put the car in fourth, hold the clutch and rev the engine does it ever pop out of gear? I first noticed mine did this when I was in a tunnel and I wanted to hear the echo sound which by the way is really cool.
IROCYOURVTEC
82-92 V6 Tech
Oct 20, 2010 01:01 AM
mjstempky
Aug 29, 2010 01:01 PM
purpl96
May 26, 2008 09:30 PM
94Ztwo8
Jun 10, 2007 10:48 AM
Gordon24Camaro
Apr 3, 2007 12:34 AM
