differential question
Old May 16, 2006 | 11:52 PM
thecamarokid's Avatar
Default differential question
i have a 91 rs and the rear axles just died on me, so i found a posi out of a 88 iroc, i was planning on taking the whole rearend and putting it in my car. will it fit in without having to change anything and also can i put my 3.08's from my diff. now and put them in the posi?
p.s. i just have the stock open differential right now.
thx
Old May 17, 2006 | 10:18 AM
blackz87's Avatar
Default RE: differential question
For starters the axle shafts are different 1988 (26 splines) vs 1991 (28 splines). Then what diff is from the 88 a 9-bolt or a 10-bolt??? They are NOT cpmpatable. You need to do more research or give more info for a correct answer.
Old May 17, 2006 | 03:16 PM
im almost positive its a 9-bolt. is there anyway i can make it fix or would i be better off just trying to find a new one.
Old May 17, 2006 | 04:00 PM
blackz87's Avatar
Like I said NOTHING from a 9-bolt will work with 10-bolt.
All the parts are NOT interchangeable. Again NOTHING.
Old May 17, 2006 | 04:04 PM
i understand that well is it a 10 bolt that is in my car right now... idk
Old May 17, 2006 | 05:33 PM
blackz87's Avatar
ORIGINAL: thecamarokid
All 3rd Gen Cars after 1989 have 10-bolt rears with 28 spline axles, so yes you have a 10-bolt 2-series carrier with that 3:08 ratio. It ia a manual (5sp) correct?
Old May 17, 2006 | 08:20 PM
yes
Old May 19, 2006 | 11:40 PM
v8chvyguy's Avatar
What happened to your origional rear end? Is it not worth rebuilding?
Old May 22, 2006 | 02:55 PM
it needs a new left axle....i just want the posi.
IndianScout
11
Jul 19, 2013 02:59 PM
JPrice
Sep 15, 2012 02:21 PM
draggo144
82-92 V8 Tech
Jan 17, 2012 12:03 PM
SickSickSick
Jun 2, 2006 10:17 AM
SickSickSick
Jun 1, 2006 09:49 AM
