DAMN IT!!!
Old Nov 6, 2008 | 09:49 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: DAMN IT!!!
a battery test may not be a bad idea. depending on ur ease of testing the starter. batteries have a habit of having enough juice to light up the car but not enough to crank. the voltage drop is what leads me to this.
if it was VATS or something else like that there would be no voltage drop because no circuit would close. batteries can get low enough that they wont even click the starter but they will still light up gauges
Old Nov 7, 2008 | 10:08 AM
irocktheIROC's Avatar
yeah, i was hopin it was somethin like that....too bad i just spent all that money on a new battery....i hope its not roached...
Old Nov 7, 2008 | 10:37 AM
Lithorian's Avatar
yea the possibility of a battery loosin cca when it's cold out is a possibility but try this first, take your cables off the battery and clean your terminals really well, brush em down to fresh lead and re connect them, make sure they are tight and see if your problem persists, also have it load tested when it's cold
Old Nov 7, 2008 | 01:28 PM
what is vats...?
Old Nov 7, 2008 | 02:02 PM
Ninja Administrator
vehicle anti theft system.
it basically means the key wont work if the car thinks its a fake.
thats why I said there would be no voltage drop if it actually was VATS. the car would just ignore you, almost like trying to start it in D
camaro97x1
Aug 14, 2008 10:39 PM
meteoralp45
Feb 5, 2008 04:59 PM
InfraredMonkey
Jul 20, 2007 07:05 PM
