Car Won't Start!!!
Old Feb 4, 2007 | 03:30 PM
  #21
ghotachevy's Avatar
Default RE: Car Won't Start!!!
did you test every cylinder for spark
if u did and have spark pull a plug and look at it if it looks like **** put new ones in and try make sure to gap them
Old Feb 5, 2007 | 01:37 AM
  #22
griff305's Avatar
i only tested one cylinder. What do u mean gap them?
Old Feb 5, 2007 | 01:45 PM
  #23
ghotachevy's Avatar
spark plugs need to have gap set to a specific meassurement at the electrode
you should go buy a repair manual for your car
Old Feb 5, 2007 | 06:22 PM
  #24
84VarinZ28's Avatar
idk if youve tried this already...but my sisters car had this problem and all i did was remove the starter and clean off all the mounting surfaces real nice so the starter can get a good ground to the block. i also cleaned off all the connections where the battery cables attached to the starter itself. that did the trick for me.
Old Feb 5, 2007 | 08:27 PM
  #25
ghotachevy's Avatar
what does starter have to do with spark??
Old Feb 5, 2007 | 09:11 PM
  #26
griff305's Avatar
i live in Canada they only sell the Haynes manuals (whic are crap) so i subscribed to all datas online manual.
Old Feb 5, 2007 | 10:05 PM
  #27
84VarinZ28's Avatar
gotachevy-
the original post (error_505) said they were having intermittent starting problems and i wasnt sure if he had tried removing the starter and cleaning up the grounds so i suggested it
Old Feb 5, 2007 | 10:48 PM
  #28
mongo's Avatar
just check your neutral safety switch anyway. my 89 rs has the same problem, but thats bcuz the kid i bought the car fromput in an after market shifter in. if thats the problem and you dont feel like messin with it, b4 you go to start it put it in neutral and pull the shifter towards you and that should ground out the switch so that you can start it. think of it as you anti theft system. it saved me 50 bucks on my insureance. just dont tell any of your friends how to start it
Lakatrae
Mar 29, 2014 10:59 AM
rdb357
Mar 30, 2008 08:25 AM
JTyler
Aug 31, 2007 10:21 PM
coco
Aug 13, 2007 10:33 AM
