Car Won't Start!!!
Old Apr 25, 2005 | 08:40 PM
erik\\\\'s Avatar
Default RE: Car Won't Start!!!
If the starter selenoid is over heating that may do it, All you said was sometimes?
on the 2.8 the pipe is like 5 inches away from the starter.
Old Apr 29, 2005 | 06:48 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
drop the starter, bench test it then wrap the whole thing with that high heat wrap. worked for me after i went through changing everything you just did
Old Feb 3, 2007 | 01:56 AM
KMS's Avatar
KMS
The same thing happened to my car. I switched the starter and it still wouldnts start, so i had a mechanic look at it and he put a new ignition switch in it and now i have no problems
Old Feb 4, 2007 | 01:27 AM
rs305's Avatar
i have a 92 rs with the pass key thing and i had the same problem. i solved it by bringing my car down to the garage and for 60 bucks they bypassed the vats system in the ignition.
Old Feb 4, 2007 | 01:05 PM
griff305's Avatar
I am having the same problem i used a jumper wire in the starter enable relay and it is cranking the motor . Injectors are pumping but it still doesnt want to start.
Old Feb 4, 2007 | 01:18 PM
ghotachevy's Avatar
but r u gettin spark
Old Feb 4, 2007 | 01:22 PM
griff305's Avatar
how should i test for spark
Old Feb 4, 2007 | 01:30 PM
ghotachevy's Avatar
go get a tester or pull a plug wire put a screw driver in it hold it by exhaust mainfold have some one crank and see if there is spark hold it real close but not touching
Old Feb 4, 2007 | 01:42 PM
griff305's Avatar
ill try that and get back to u
Old Feb 4, 2007 | 02:47 PM
  #20
griff305's Avatar
I am getting spark
