89 camaro Irock with ls1 question an problems
Old Sep 2, 2011 | 10:54 PM
redchevyls198's Avatar
Default 89 camaro Irock with ls1 question an problems
im building an 89 camaro irock with an ls1 motor from a 98 camaro an i had a couple of question i would like to ask 1. Could i use the stock driveshaft of the 89 camaro or do i need an aftermarket one ? 2.what kind a fuel pump do i need do i need to use a regulator or no ? 3.an whose doing the computer chip to take of the security on the computer ....
Old Sep 3, 2011 | 07:28 AM
blackz87's Avatar
All of the above questions are the least of your problems. If you don't know if you have a IROC or irock.
Old Sep 3, 2011 | 10:10 AM
torque_is_good's Avatar
Sorry, please come clean
who is attempting to do this build or are you hoping to do it in the future?
Did the person purchase an entire donor car or just the engine?
Please provide details on exactly what is going on, or hope to occur, and then answers can be given
Old Sep 3, 2011 | 10:47 AM
Ok I have an 89 Iroc with an LS1 swap the motor is in. Oready what else do I need besides the motor to get my car started an run
Old Sep 3, 2011 | 12:54 PM
djs383's Avatar
You will need a bucket of $100 bills....
You will need to get the motor in the bay, which will be no small feat in and of itself, beyond that you'll need at least:
1. A way to deliver fuel. You need to find what the 98 camaro's GPH pump was, and then see if you can retrofit one in your tank.
2. You'll need to figure what trans was attached, I think it was still a 4L60E, if so you are in luck. The bad news is that I am 99% sure due to the differences in mounting location you will need a fab'd crossmember and then that will throw off your torque arm mounting location.
3. You will need the entire computer from that 1998 car to make your ignition, timing, injectors, and trans work.
4. Your gauges will not work. I am again 99% sure sending units were different on the LS1 than the L98.
5. Another bucket of money...
Old Sep 3, 2011 | 09:59 PM
Ok anything else that I might need for the camaro because the motor is in the transmission to so anything I need to know
Old Sep 4, 2011 | 08:52 AM
one more time
details and actual facts would be very helpful.
If it's buddy's dad's car then get as many details from the dad, post up the questions here and we'll be glad to help.
To begin, what exactly exists today and in what shape. Was a complete donor vehicle purchased ?
Old Sep 4, 2011 | 10:11 AM
Installing a LS1 in other cars is very common. The 3rd gen is a good move becaue the computer is not tied into everything. If you check out the project section we have a member that just finished a putting one in a 77 Camaro. You can make your original harness work but it will look pretty ugly when it done. You can buy a harness from Painless and send your PCM out for a tune and they can disable all the crap you don't need. We do not have many people who have done the type of swap but there are a lot out there. I can not send you link to other forum but if you search. Painless LS1 Swap in google you will find them. Please do a build thread and give us as much info as possible.
For the fuel system you need to get to a pump the has both the correct pressure and more then enough gallons per minute. To get it started you just need the pressure. Low GMP will limit your HP.
Thanks.
SpaghettiChris
May 2, 2013 06:13 PM
tespjs12
Apr 16, 2012 02:03 AM
redchevyls198
Oct 9, 2011 11:03 PM
dakotakid
82-92 V6 Tech
Jun 18, 2009 02:36 PM
NFG687
Mar 5, 2007 07:20 PM
