88 camaro no turn signals
Old Mar 11, 2020 | 10:05 PM
Mr.sendbot's Avatar
Default 88 camaro no turn signals
So i finnaly got my camaro out of the icy grave and i just discovered it didnt have any turn signals :/ and i just replaced the flasher module and signal switch assembly and still nothing. The hazard lights still work too so im stumped. It could be a simple fuse or a grounding issue but i would love some feedback on what im missing. Thanks
Old Mar 12, 2020 | 07:31 AM
Everett#2390's Avatar
Each circuit, Turn, Stop/Brake, and Emergency have their own power source and power goes through turn signal switch.
You might swap the flashers or replace the one for emergency flashers.
Welcome to the club.
Old Mar 12, 2020 | 08:53 PM
Mr.sendbot's Avatar
So ive replaced the emerg solenoid and still nothing. I started poking around with a test light and found that theres no power going to the flasher solenoid. But i cant seem to find out where the wire goes too, my haynes manual wont tell me much about the harness so im kinda lost as to where i should be looking. And i dont really feel like pulling the loom apart and playing with spaghetti to figure it out. I feel pretty dumb cause it should be an easy to find/fix 😅 but i just cant figure it out. But thank you for the warm welcome!
Old Mar 12, 2020 | 10:28 PM
peterpar's Avatar
If the 3rd generation Camaro is wired like the 4th, the turn signal circuit power supply is routed through the ignition switch to the fuse block and then through flasher and turn signal switch to the turn signal lamps. The first thing I would check is what Everett suggested, the fuse for the turn signals. Both sides of the fuse should have 12V to a ground with the ignition switch in the run position. If there is no power on either side of the fuse, then chances are the contacts in the ignition switch are bad. A factory service manual is priceless in a situation like this. You can usually find them on eBay for $25 or under.
PushrodLSX
Dec 27, 2017 06:58 AM
side-winder
Jun 24, 2014 06:03 AM
New2Camaro
Aug 31, 2009 08:02 PM
dustinb
May 1, 2008 06:27 PM
NITRIS
Apr 29, 2007 04:15 AM
