No Turn Signals
Old Aug 16, 2009 | 11:14 AM
New2Camaro's Avatar
Default No Turn Signals
Signals went out on me last night. Fuse is good. Reverse (which is the same fuse), markers, and flashers all work. What else can I check? Thanks.
Old Aug 16, 2009 | 11:18 AM
osduck5's Avatar
Could it be the turn signal switch mounted in the steering column?
Old Aug 16, 2009 | 11:33 AM
02StanGT's Avatar
i'm going to say the signal flasher under the dash. it is separate from the hazards.
Old Aug 16, 2009 | 03:41 PM
New2Camaro's Avatar
My first thought was the signal switch too but I'll look at the flasher first. Thanks.
Old Aug 16, 2009 | 06:02 PM
osduck5's Avatar
I would look at the flasher first as well, Alot cheaper fix and alot easier. I didn't realize that it was a seperate flasher than the hazard flasher.
Old Aug 16, 2009 | 06:23 PM
02StanGT's Avatar
i don't think alot of people do.
Old Aug 18, 2009 | 09:55 PM
tripwire1124's Avatar
one time mine went out but it was only on one side and all i needed to do was replace the bulb and it was fine.
Old Aug 19, 2009 | 11:19 AM
Jonny Dubyah's Avatar
yea i burn through left blinker bulbs like a fat kid eats cupcakes (the previous owners didnt lock the bulb in right and it melted the plastic so now its always resting on the plastic) and when it goes out my rear light just stays on when i go to signal
Old Aug 19, 2009 | 11:55 AM
shawnathan's Avatar
sounds like u need some blinker fluid to me
Old Aug 20, 2009 | 04:47 PM
Envisi0n91's Avatar
same with me, lmao! I had to buy new sockets and light fixtures for both of my front end blinkers because everything was melted. There were 3 dead bulbs inside the light.
