No Turn Signals
Signals went out on me last night. Fuse is good. Reverse (which is the same fuse), markers, and flashers all work. What else can I check? Thanks.
Could it be the turn signal switch mounted in the steering column?
i'm going to say the signal flasher under the dash. it is separate from the hazards.
My first thought was the signal switch too but I'll look at the flasher first. Thanks.
I would look at the flasher first as well, Alot cheaper fix and alot easier. I didn't realize that it was a seperate flasher than the hazard flasher.
i don't think alot of people do.
one time mine went out but it was only on one side and all i needed to do was replace the bulb and it was fine.
yea i burn through left blinker bulbs like a fat kid eats cupcakes (the previous owners didnt lock the bulb in right and it melted the plastic so now its always resting on the plastic) and when it goes out my rear light just stays on when i go to signal
sounds like u need some blinker fluid to me
Originally Posted by Jonny Dubyah
(Post 356113)
