82' trans problem
Old May 30, 2006 | 12:09 AM
chevytt350's Avatar
Default 82' trans problem
i have a 1982 camaro i have just purchased , and i am not sure if the trans if a 200r or not, its says metric on the pan, but here is my issue, the trans is no good, i have a 700r4 and i am not sure if it will work, because the 700R4 trans is electronic, can anyone help me?
Old May 30, 2006 | 12:52 AM
Default RE: 82' trans problem
The 700R4 is not electronic, the only electrical control is for the TCC which can be easily rigged up for manual control. However, if the transmission is a 4L60E, which looks like the 700R4, it won't work in you car without a stand alone control module. The other problem amy be the bell housing, which came in various configurations.
Old Jun 8, 2006 | 10:06 PM
chevytt350's Avatar
what do i do about the lock up convertor i dont want to burn up the trans, and will the drive shaft fit with the 700R4
txchevyguy
Jul 18, 2012 10:34 PM
mattzilla_22
May 17, 2010 10:04 PM
chvtrk7593
Mar 30, 2009 04:57 PM
noz
Feb 27, 2008 03:17 PM
1993camaroz28
Apr 25, 2007 08:56 PM
