LT1/LT4 Tech 1993-1997
trans problem
Old Feb 27, 2008 | 02:48 PM
noz's Avatar
noz
Default trans problem
i have a 1995 camaro z28 i berly bought the car i dont know if is the trans. or the clutch, the problems starts when im in neutral, the trans starts to grind and in first gear too..after that the car is perfect. i'll appreciate if someone can help me thanks.
Old Feb 27, 2008 | 03:17 PM
SpecterGT260's Avatar
Ninja Administrator
Default RE: trans problem
your first gear syncro may be a little rough. how bad is the grinding? if it is just enough that u only notice a couple bumps its not worth getting bent out of shape over. if its a serious grind you may want to consider having the syncros fixed
Tom071
70-81 Transmission & Differential
Apr 8, 2014 09:33 AM
txchevyguy
Jul 18, 2012 10:34 PM
mattzilla_22
May 17, 2010 10:04 PM
chvtrk7593
Mar 30, 2009 04:57 PM
1993camaroz28
Apr 25, 2007 08:56 PM
