Yet another carb question
Old Sep 4, 2013 | 08:59 PM
chambr's Avatar
Default Yet another carb question
Cars a 79 Z28...
Carb has an accelerator pump issue so thinking about replacing the whole unit ..
355 cu in
comp cams xe274 -- .490 lift split duration 230/236
Performer RPM intake
Aluminum heads -- 2.02/160 valves 200 cc runners -- springs set up for .525 lift
65K HEI with Accel ECU
1 5/8 headman headers
turbo 350 with B&M Holeshot Converter (2400 rpm)
3.42 gears
Currently has an Edelbrock 1406 600 cfm carb .. this is a fuel saving carb (not what i am looking for) ..
Thinking I need something in the 650 --750 range with vac secondaries .. Is 750 to big or should I look for a 650???
Thoughts ???
Also any speculation on HP/Torque in this setup ????
Looking forward to your advice ..
-Mike-
Old Sep 5, 2013 | 12:41 PM
If you're looking for a carb with good lowend and midrange response, then the vacuum secondary carb is a great choice. I like to go smaller usually, but the way your engine is set up a 750 wouldn't over carb the engine if it's vacuum secondary. A 650 would work, but not sure how high rpm response would be.
Old Sep 5, 2013 | 03:54 PM
chambr's Avatar
Thanks for the feedback .. I was leaning towards the 650 myself .. sometime you just have to bounce things off other people for their thoughts
jimm418
70-81 V8 Tech
11
Jun 21, 2014 02:54 PM
1977Camaro350
Mar 23, 2012 12:35 PM
cadmanof50s
Sep 21, 2010 02:23 PM
MrOz87
Feb 17, 2007 06:15 PM
Jaguar543
Jan 26, 2007 03:32 PM
