Carb Question
Old Feb 17, 2007 | 03:50 PM
MrOz87's Avatar
Default Carb Question
Just built a 350 with about a 0.500 lift on the cam, edelbrock preformer intake, 2.02 1.60 iron heads and I'm having a problem with the carb. Bought a 600 cfm edelbrock with an electric choke and vacuum secondaries. I'm having some trouble at idle...sometimes it idles kinda high. Also I think its running pretty rich. I was thinking that I need new metering rods but I'm not sure. Does anyone have any ideas on how to tune the carb so I can have a nice idle and so that it won't run so rich?? Thanks
Old Feb 17, 2007 | 05:50 PM
MadMikeZ28's Avatar
Default RE: Carb Question
I never liked those carters. A common problem with them from new is bad throttle shaft bushings. See if your throttle shaft has any movment. Could be drawing air.
Old Feb 17, 2007 | 05:56 PM
MrOz87's Avatar
Is there anybody that makes new bushings or do you just recommend a different carb? Maybe a Holley?
Old Feb 17, 2007 | 06:05 PM
MadMikeZ28's Avatar
I would check them first. If they are bad you should be able to move the throttle up and down and around. And you can get them rebushed. It usualy takes a tool to ream and resized bushings though.
Old Feb 17, 2007 | 06:15 PM
MrOz87's Avatar
So its probably not the metering rods or jets that are causing the high/rich idle?
jimm418
70-81 V8 Tech
11
Jun 21, 2014 02:54 PM
chambr
70-81 V8 Tech
Sep 5, 2013 03:54 PM
1977Camaro350
Mar 23, 2012 12:35 PM
cadmanof50s
Sep 21, 2010 02:23 PM
Jaguar543
Jan 26, 2007 03:32 PM
