Temperature Sensor
Old Jun 10, 2010 | 08:10 PM
drswitala's Avatar
Default Temperature Sensor
Where is the coolant temperature sensor located on a 1980 Z 28 engine?
I was told on the intake manifold but mine is not stock and has no sensor.
Old Jun 10, 2010 | 08:30 PM
gfrench's Avatar
even on an after market intake it is at the front on the drivers side next to the thermostat. It is normally a brass fitting with a line running to your dash.
Old Jun 11, 2010 | 02:22 PM
drswitala's Avatar
Thanks, I will check it out this weekend.
Gauge is not working so I thought I would check that first.
Old Jun 13, 2010 | 02:37 PM
drswitala's Avatar
Found it or more like where it should be.
The PO had it plugged. No seansor and god knows where the pigtail fo it is.
No wonder the gauge is not working.
Thanks.
auto
Mar 30, 2012 09:34 AM
fuhhuayt
May 5, 2011 01:04 PM
akleeve
82-92 V6 Tech
Mar 24, 2010 09:30 PM
ralphz28
Aug 4, 2008 09:06 PM
3.4CamaroCDOG
Jan 19, 2008 10:21 PM
