Visor Mounts
Old Jun 13, 2010 | 02:47 PM
drswitala's Avatar
Default Visor Mounts
Do the three mounting screws have metal anchoring holes or do they just srcew into the headliner board?
The PO installed a new headliner but did not reinstall the visor hardware.
I can feel the large center holes through the felt for the spring loaded swivals to go through but not the screw holes.
I would hate to F-Up the new liner mounting these things.
Old Jun 14, 2010 | 05:54 PM
nj85z28's Avatar
Senior Administrator
February 2012 ROTM
May 2012 ROTM
There should be holes up there someplace in the metal.
Old Jun 14, 2010 | 08:00 PM
drswitala's Avatar
Thanks.
I think I can fish around for them with a sewing needle and not damage the headliner material.
Old Jun 16, 2010 | 10:44 PM
Be sure your visors are mounted in the correct direction too! I accidentally swapped mine left to right and they don't swing correctly. Had to swap them back to allow them to move and lay right.
Old Jun 16, 2010 | 10:47 PM
Chaotic94's Avatar
September 2011 ROTM
There are holes in the metal above the headliner. I had my headliner redone and had the same issue. They covered up the holes. I ended up doing what you're doing with the sewing needle. It worked for me. lol Except I used a tooth pick. Luckily I only stabbed it through where the visor mount sits Otherwise I'd have little holes showing all over the place
Old Jun 16, 2010 | 10:58 PM
I did my own headliner and just screwed the screws into the holes before installing the liner. Then after it was in I used a knife to poke the heads through the liner and mount the visors.
Old Jun 17, 2010 | 06:59 PM
drswitala's Avatar
Thanks again all for the advice.
GrandmasCar
Aug 14, 2010 09:42 PM
CamaroZ99
Jul 11, 2010 11:30 PM
froggie_adp
Jun 28, 2010 11:35 AM
reaper2702
Sep 5, 2009 11:42 PM
libertyforall1776
Oct 11, 2007 08:30 AM
