Tremec TKO Noise? HELP!
Old Aug 22, 2007 | 11:32 PM
yostjo70's Avatar
Default Tremec TKO Noise? HELP!
Hey guys,
I recently put a tremec TKO 500 in my 1970 Camaro, and it now has around 12000 miles on it. and it has developed somewhat of a noise while sitting in neutral. The noise is sort of like a rattle but more muffled and the gears can be heard spinning. but when you push the clutch in it goes away. I am sure the noise is being made while the car is on the highway but there is so much exhaust noise it would be impossible to tell. The motor does have a vibration around 3000 rpm's, this has been there since the motor was new. the transmission shifts smoothly and does not whine terribly loud.
Please help, i really need to figure this out before i do any damage if there is a chance of that.
thanks,
joe
Old Aug 31, 2007 | 12:14 PM
t9ojetpilot's Avatar
Default RE: Tremec TKO Noise? HELP!
[&:] sounds like a classic example of an input shaft bearing on the trans.
Softail
Dec 4, 2011 08:53 PM
JLink3
LS Series Tech
Jun 8, 2009 05:29 PM
JLink3
LS Series Tech
Apr 28, 2009 06:37 AM
Whistle Pig
Nov 18, 2005 02:52 AM
