81 Z28 Shifting Problems
Old Aug 24, 2008 | 01:59 PM
mrriverajr's Avatar
Default 81 Z28 Shifting Problems
My 4spd transmission is having a real hard time downshifting from 3rd to 2nd. I have to force it into 2nd gear sometimes. What could be causing this? What could I do to fix it? Any pictures or details could really help.
Old Aug 24, 2008 | 07:11 PM
Default RE: 81 Z28 Shifting Problems
Your second gear synchronizer is going out. They tend to keep getting worse with miles.
Call around to tranny shops and find one that will work on Manuals. Then get out your check book. Manual trany work if not hard but ifyou do know know how to tell a sync is out chances are you will not have the tools required to do the work. You could save yourself a few buck by pulling the trans out yourself. Make sure the tech drives the car before you pull it.
jcase350
82-92 V8 Tech
Oct 29, 2012 01:46 PM
slvr95camaro
Jul 8, 2009 01:33 PM
IROC444
Aug 23, 2008 08:40 PM
92lxsleeper
Aug 15, 2008 08:04 PM
firehouse4
May 21, 2007 06:57 PM
