Factory rear end question
Old Aug 15, 2012 | 04:51 PM
BLK79's Avatar
Default Factory rear end question
Can I install a posi into my factory rear that has 2.41 gears in it and will it work ?
This is for my 79 Camaro
Old Aug 15, 2012 | 04:53 PM
BasicConcepts's Avatar
Technical User
ohh ya just swap out the center section with a LSD and you can also change the gearing to a 3.23 or a 3.73 (really any gearing you want) is this a 10 bolt?
Old Aug 15, 2012 | 06:08 PM
Edwardgp's Avatar
Do you already have the posi?
Old Aug 15, 2012 | 07:04 PM
BLK79's Avatar
I pretty sure its a 10 bolt, i"d be suprised if it was anymore.
Nope, not yet but hopefully soon.
I was thinking of a Auburn pro posi.
Old Aug 16, 2012 | 02:03 PM
All the 8.5" 10 bolt rears on 2nd Gens are the same housing. The carriers are sized for the ring gear, so if you're going to change to a 3 series, you need to change to a 3 series posi carrier to accept that ring gear.
They do make ring gear spacers that will allow you to install a 2 series posi carrier and a 3 series ring gear with a spacer. I just went through this last year with my Chevy powered Austin gasser that had a weird rearend in it. Couldn't find a posi carrier, or a proper 3 series carrier, so I ended up using the spacer and it is working great with my 3.73 gear set.
Old Aug 16, 2012 | 02:54 PM
Has anybody here tried the Powertrax Traction Systems (not talking about the Lock-Right). Liked it or no? The nice thing is it fits into your existing carrier and you don't have to setup your gears. POWERTRAX® EXTREME TRACTION SYSTEMS
Old Aug 16, 2012 | 05:43 PM
Edwardgp's Avatar
BLK79 maybe the power trax would be right for you.
Old Aug 16, 2012 | 07:56 PM
Hey Camaro-69, why didn't you think of that?
Old Aug 16, 2012 | 07:57 PM
I've had a Power Trax locker in my Camaro since 1978. I like it, and no problems.
Old Aug 17, 2012 | 08:36 AM
Edwardgp's Avatar
Let us know what you decide and how it worked out.
ragtag
Jan 19, 2014 07:43 PM
hooknladder
Mar 26, 2011 11:44 PM
Detector
May 10, 2010 04:04 PM
microkid
Feb 9, 2010 08:50 PM
bassmaster
Mar 12, 2007 02:12 AM
