Factory rear end question
Can I install a posi into my factory rear that has 2.41 gears in it and will it work ?
This is for my 79 Camaro |
ohh ya just swap out the center section with a LSD and you can also change the gearing to a 3.23 or a 3.73 (really any gearing you want) is this a 10 bolt?
Do you already have the posi?
(Post 639889)
Originally Posted by Edwardgp
(Post 639905)
I was thinking of a Auburn pro posi. :icon_shrug: |
Originally Posted by BLK79
(Post 639930)
I pretty sure its a 10 bolt, i"d be suprised if it was anymore.
Nope, not yet but hopefully soon. I was thinking of a Auburn pro posi. :icon_shrug: They do make ring gear spacers that will allow you to install a 2 series posi carrier and a 3 series ring gear with a spacer. I just went through this last year with my Chevy powered Austin gasser that had a weird rearend in it. Couldn't find a posi carrier, or a proper 3 series carrier, so I ended up using the spacer and it is working great with my 3.73 gear set. |
Has anybody here tried the Powertrax Traction Systems (not talking about the Lock-Right). Liked it or no? The nice thing is it fits into your existing carrier and you don't have to setup your gears. POWERTRAX® EXTREME TRACTION SYSTEMS
BLK79 maybe the power trax would be right for you.
(Post 640130)
(Post 640106)
Let us know what you decide and how it worked out.
