78 z28 transmission leak
Old Jun 1, 2019 | 06:23 PM
zech's Avatar
Default 78 z28 transmission leak
hey all, got a project 78 z28(manual transmission), came with a brand new 355 crate motor and a new trans as well. The trans had never had fluid in it so i tried to put some in today to get the tranny functioning. fluid started pouring out of a hole in the transmission on the passenger side near the engine bay which is depicted in the second picture provided. Is there a plug or line that is supposed to belong there? Thanks! (second pic is for reference as to where i'm talking about)
large hole with the light on it is the leaking point of the transmission
Old Jun 1, 2019 | 08:10 PM
Zspoiler's Avatar
Thats not a 4 speed manual..Thats an automatic transmission.And thats where Dip stick usually goes.
Old Jun 1, 2019 | 09:08 PM
zech's Avatar
[QUOTE=Zspoiler;731833]Thats not a 4 speed manual..Thats an automatic transmission.And thats where Dip stick usually goes.[/QUOT
Thank you for the correction, it is indeed an automatic I don't know why I said manual lol, after some research I believe it to be the overdrive cable? Because the dipstick is in the engine bay and there is a small hook type assembly inside the hole where the linkage was coming from , I was able to get ahold of the previous owner who started this project and he said that's indeed what it was. Thoughts?
Old Jun 2, 2019 | 11:43 PM
OldMech's Avatar
Yep! Kick down cable, you can see the hole where the bolt goes to hold it in place. Plastic piece on the end of the cable with an o ring on it slides in there, and the bolt secures it. But, your going to have to drop the pan to get the little Z clip into the linkage.
Brian Z.
Dec 15, 2014 08:53 AM
NJZ28
Jun 27, 2011 09:37 PM
Camarock
Nov 16, 2008 08:37 PM
speedy9220
Sep 3, 2008 08:37 PM
thebandit110
Feb 12, 2008 10:02 AM
