Dumb Question: Trans fluid leaking from speedometer cable attachment
Old Dec 7, 2014 | 06:18 PM
Brian Z.'s Avatar
Default Dumb Question: Trans fluid leaking from speedometer cable attachment
Trans fluid is leaking from where the speedometer cable enters the trans on my '81 Camaro with the turbo350 trans. I took the nut off but there doesn't seems to be a good way to seal that to keep it from leaking. What am I missing? I'm sure it's something simple so I apologize in advance for the dumb question.
Old Dec 9, 2014 | 12:25 AM
greencamaro1981's Avatar
did you take the nut just to the side off it off and the small plate/tab and pull the gear assembly out there is an o ring on the assembly that can go bad
Old Dec 9, 2014 | 10:14 AM
Brian Z.'s Avatar
I took the nut off but did not take off the small plate/tab. I will do that and get a new o-ring. Any idea what the o-ring is called? Thanks.
Old Dec 9, 2014 | 10:35 AM
If it were mine, I wouldn't waste my time replacing just the o-ring. Leaking fluid around the speedometer gear housing is not an uncommon thing, especially with an old worn cast aluminum housing. Mine leaked badly when sitting for more than a week, and an o-ring didn't help. This steel housing, which was designed to fix the leak issue, did do the trick quite well though: Speedometer Gear Housing
Old Dec 15, 2014 | 08:40 AM
Ditto. If you're going to pull the gear housing, I'd replace it. There's an inner and outer seal, and the new housing comes with both. It will definitely fix whichever is the problem.
Old Dec 15, 2014 | 08:53 AM
Brian Z.'s Avatar
Thanks for all the replies. I did order the part and should be able to install it this upcoming weekend.
klong2194
Dec 28, 2011 08:36 PM
bd92rs
Mar 13, 2009 06:38 PM
shippy8907
Feb 28, 2009 10:52 PM
drtask
82-92 V6 Tech
Feb 3, 2008 09:36 PM
BobbyX
70-81 V8 Tech
Nov 15, 2007 01:58 PM
