So here it goes, my project thread (2nd gen)
#192
Where did you cut your trans tunnel? I saw that you got the hump, I don't have that luxury, but I kind of figured if I cut my tunnel around where the auto shifter was bolted down I should have enough room. Thoughts?
#193
Its very close to the big round hole for the stock shifter. My hurst shifter has a plate that bolt to the tranny the the shifter bolts to it. I left the plate on and jack the tranny up untill it hit the floor. Then I got insde and looked through the round hole and made my first cut to the left of the hole going front to back. Then trying to make a rectancle cut from there as close to the same size as the shfter body. I brought the shifter through the bottom and got the bottom bolt started. Then it was just triming alittle at a time until I could get the top bolt in from the top side. I could have lft it right there but Having the hump on there it would leave a space where debri can build up and if its moist, will eventually give the dreaded rust a place to start. To get around that I put the hump on and centered the shifter, then took a paint marker and outlined the hump. I took the shifter back out and cut out to about two inches from the line. Then reinstall and hook up the linkage.
#194
I would think the 3.73 gears would be OK for racing. Maybe a bit lower around 4.11 would be better, but the 3.73 would be better all around.
#195
Yeah I can do that for you tomorrow in the day but not sure how accurate it will be (gravel's not really level). my suspension is all stock and I don't have any aluminum parts so the motor is pretty heavy. But I'll check it out if you want still.
#196
I will take it out don't get me wrong. I was going to the track while I was still in my moms belly, born into it. I plan on dialing in my timing there. I just wanted something different this time. If it goes 12 flat while spinning hard I'll be happy. Future plans are for a Procharged 427 small block and overdrive. It will be fast where ever I drive it then.
#197
#198
Its cool man. If you have any questions I usually have my laptop in the living room and switch back and forth from the tv to computer all day. Not much else to do with the littles ones running around here. I never sleep anymore.
#199
i just went and measured mine for ya...its 21 1/4" from the middle point of the front bumper (above the lower grill below the top grill[that point]) to the ground and 27 3/4" from the top of the rear wheel arch to the ground on mine....hope that helps im not sure if its stock but its probably pretty close
