So here it goes, my project thread (2nd gen)
Old Mar 9, 2014 | 01:27 PM
  #1061
clacia's Avatar
Originally Posted by 77nomad
They are a bit soft but I dont think they will hook for crap. They are a street performance tire. More for cornering with a stiff side wall. Nitto makes a N555DR that is a drag radial. But if I go drag racing I'l more than likely bolt on my 15" wheels with a real set of ET Streets. There is no point in trying to get a short tire to hook. 15's fit over my brakes and a the tires will be a true wrinkle wall design, not a compromise.
I understand you where you mention the DSE minitub kit where it re-locates the spring perches and notch the frame rail. I did not want to notch the frame rails and relocate the front spring perches. I am trying to keep the body as stock as possible and avoid cutting and welding.
Instead I went for ridetech where they use the same front perches but the lower bar is welded on the inside to gain about 1" tyre clearance than the standard leave spring. As well the coil overs are mounted inside of the frame rails and not like the stock shocks.
Just a quick one - how much tyre clearance shall I leave between the Inner rear fender and the rubber? 1/2" is enough or I need to leave more space? Any idea?
Old Mar 9, 2014 | 03:36 PM
  #1062
I really cant answer that. If it were a drag car I wouldnt care how much there was because they will just pull away as the car accelerates. Depending how stiff your tire is and how you plan on using the car come into play. Your "hard driving" could be my warm up lap.
Old Mar 10, 2014 | 01:45 PM
  #1063
clacia's Avatar
In fact my hard driving will be your warm up lap I am going for Michelin Pilot Sport so they are pretty much hard on side wall.
I will order a 295 tyre and install it to see how it sits inside the wheel well. I will post pics when I have them.
Old Mar 11, 2014 | 05:18 PM
  #1064
I am hard on cars. Its my nature to find their or my limit. With my new trans I'll either run out of ***** or road before I find the top end.
Old Mar 11, 2014 | 05:27 PM
  #1065
clacia's Avatar
That is great. Will post some photos soon.
Old Sep 14, 2014 | 10:42 PM
  #1066
TestCarDatabase's Avatar
Nice build thread! I can't wait to see the end product!
Tony Huntimer
TestCarDatabase.com
Old Jul 3, 2015 | 02:15 PM
  #1067
Sudstoy's Avatar
Anything new in these last 10 months?
80ZJoe
Aug 11, 2012 06:23 PM
gfrench
May 16, 2011 08:35 AM
iCrossbone
May 3, 2011 08:19 PM
MaVeN
Apr 23, 2011 05:33 PM
1987IROCZ
82-92 V8 Tech
Feb 19, 2010 02:08 AM
