New Build Thread?
#241
I think for that amount of work I would have to love it. I don't,so I'll use the bumper.
It's time to start the rest of the body. All the black must go.
The rest of my Mike Lavallee wannabe flame job goes also.
#242
This is the repro outer door seal.It never fit right.I had to cut and bend it.
the paint was so soft it dented where the spoiler was.
#245
I stripped one quarter. I found one bubble came from under the bondo where the previous owner replaced the quarter. I also tried out a different trunk lid. The fit is no better.
I ground out all the bondo and redid it. What a messy job!
#249
I don't use anything that won't go on a DA. Just the metal finisher still living in me. The flap disc and such can create too much heat and you can get edge cut pretty easy. I use them for grinding down welds and blending corners on thicker material.
#250
The paint was pretty soft. I did it with 80g. I could see when I hit primer. I did it mostly by hand with the long blocks. Blocking out will be much easier this way. One reason I tried a diff trunk lid was that I didn't have to remove all the paint. Just scuff and shoot. But it has issues and I'll be going back I think.
