My 1970 Camaro w/ 572 Build
Old 01-12-2014, 02:35 PM
Probably the spot that gives me the most uneasy feeling is the cage/interior order of completion. I want/need a cage. I also want a comfy ride and the bars as close to the shell as humanly possible. i really will have to buy a bender and just have at it until I like it. I just dont trust anyone to get it EXACTLY were I want it. Not for lack of trying either. I just want it to blend into the car because I'm so tall, well kind of wide now too. But the car cant be tight on me. My Nova was the worst. I could hardly see due to the halo bar and padding coming down right into my line of sight. I couldnt sit the seat any lower either. couldnt lean it back any farther because the seat belt bar was in the way.
  #342
Old 01-12-2014, 03:49 PM
clacia's Avatar
What about ridetech rollcage? it is specially made for the second gen camaro and is a bolt on as well. although a little bit expensive!! Looks neat as well but I do not know if it makes the purpose?? Any idea?
  #343
Old 01-12-2014, 06:20 PM
Its not a NHRA legal cage though.
  #344
Old 01-12-2014, 10:37 PM
Sudstoy's Avatar
I am hoping to run mid 10s and have to have a certified cage. My cage guy told me to have all of the seats in the car and in the correct position so he can place the cage where it needs to be.
  #345
Old 01-13-2014, 02:16 AM
Sudstoy's Avatar
Any idea on where to get one of those bars at?
Originally Posted by 77nomad
Sorry, it is a known fact the drop in rads are too tall. Most are just due to the cap being straight up and not on a 45* angle like stock. As Val said most of us cut the lower support. You basically have to cut the bottom out and then weld in filler panels to box it back in. It happens on everything from cheap to 2k rads. You could also lean it forward or back to drop the top down. I have a brace between my frame rails under mine so my plane was to drop it down to there. He is a pic of one like mine. The silver bar isnt stock but makes a nice ledge to set the rad on.
Please post up the tips your interior guy gave you. Never know, it may be something none of us have ever heard of or seen but is completely logical.
  #346
Old 01-13-2014, 09:45 AM
I'm guessing since it's all welded in, it may be a custom built tube under the front pictured. Sure wouldn't take much to build one.
  #347
Old 01-13-2014, 09:38 PM
Sudstoy's Avatar
So i spoke with my buddy last night who has the shop. Not much has been done yet but then again i didnt expect much.
Question of the day, what would your guys recommendations be for a drive line? Should i go aluminum? need to get one or order ASAP.
  #348
Old 01-14-2014, 08:44 AM
I've never used an aluminum driveline, so can't really say much about them. I would try to stay with the largest diameter driveline, as diameter is where you get the most strength.
  #349
Old 01-14-2014, 01:47 PM
clacia's Avatar
Originally Posted by Sudstoy
He is as you put it charging NASA money, he quoted me $2200 for full 3.5" aluminum dual exhaust. Not sure what material im gonna use yet. Also it was aroundd $2000 for the cage.
This was before he was a fulltime shop, hopefully the prices never change too much.
Hi, was reading your post on roll cage. What material is he going to use? Will it be completely welded in? Not too much expensive for $2000 when considering $3000 from ridetech. Can he ship to other countries? I will be interested in one. Thank you
And by the way, well done on your built. Very nice. I am reading every step.
  #350
Old 01-14-2014, 05:20 PM
I would use Dennys Nitrous ready shaft. They will replace it if it ever twists or breaks. They wont do that with their aluminum ones. At $400 its not that bad either.
I got my bar from custom works. Keith is the owner and a good guy. He also drives a early second gen. www.customworksproducts.com
Quick Reply: My 1970 Camaro w/ 572 Build
