Cobalt Blue 79z28
Old Jan 5, 2012 | 12:09 PM
  #221
bad436z28's Avatar
hello all i will begin my new project today the radiator core support,needs lots of fabrication as i want to put some extra bracing in it and make the mounts for my twin transmission coolers.
Old Jan 5, 2012 | 04:54 PM
  #222
LOL I can smell Gary as I approach on the way to Chicago. I've stopped looking for fireworks there too. Not my favorite place.
I'd like to see the twin coolers.
Old Jan 5, 2012 | 06:27 PM
  #223
Just wondering why you're using twin tranny coolers? You really don't want to get the tranny fluid too cool, or that can cause issues too.
Old Jan 5, 2012 | 07:56 PM
  #224
bad436z28's Avatar
because when i went to buy my tranny coolers all they had where the little ones,two of them equaled one large one.there not very big maybe 6x6,each each one is only rated at 10,000 gvw.
Old Jan 5, 2012 | 07:57 PM
  #225
bad436z28's Avatar
i probably should have waited and just got the large towing one like i wanted.ok damon when i get them mounted i will take a picture how i did it.
Old Jan 6, 2012 | 11:21 AM
  #226
Well I guess that should keep you cool to 20,000 gvw when you're hauling those other 4 Camaros behind you!
Old Jan 6, 2012 | 02:55 PM
  #227
bad436z28's Avatar
yeah.hAhaha i only have 2 camaros i can bring it down to 1 10,000 if u think thats enough ,just thought it might get hot at the dragstrip i have 3500-3800 torque convertor and soon to be manual valve body,i know it will stay cool on the street,i only run them thru the coolers not the radiator too.i can try one and see how that does then add #2 only if needed,thx for the tip if i wont need it then i can return the second one.val i really appreciate all the tips u gave me so far much appreciated i do listen to all u say.this is all new to me the only thing i ever raced was sprint cars.and took my irocz to a couple test and tunes at my local drag strip
Old Jan 6, 2012 | 03:12 PM
  #228
rydeer's Avatar
your going to run a 35 to 38 tq conv. Man you will hate that on the street. And yes you will make heat! I'm getting rid of my 32 and going to a 22. I want to be able to pul out of my driveway with out revving to kingdom come!
Old Jan 6, 2012 | 04:08 PM
  #229
bad436z28's Avatar
yeah i will probably end up going down to maybe a 2500 stall we will see once i get it on the road,i got the big stall so i could use it at the drag strip too.when i had that engine in my 87 iroc for 3 weeks i ran it with my 700 r4 stock convertor and it did fine but wouldnt want that on the dragstrip so i need to find a happy medium.
Old Jan 6, 2012 | 05:42 PM
  #230
I agree with Rydeer, that's way too high a stall speed. I'm running a 2,000 on my '71 and a 2200 on my Austin. I'd sure want lower converter stall or you'll lose a tranny from not being full pressure while at cruising speeds.
I'd run just one of those coolers, and isolate it from the radiator. I always cut the tranny lines from the radiator and isolate my coolers so radiator heat doesn't add to the tranny's temps, or vice versa.
