79 Camaro Project
Old 05-04-2010 | 07:00 PM
LOL I just woke up. Ok, so I'll never be a carpenter. 3/4 is still a big bar. The one in my Z is only 5/8.
  #242
Old 05-04-2010 | 07:28 PM
ATM's Avatar
ATM
lol, that is just too funny. I wanted a 7/8" bar, but this will do for now. I still need the brackets to mount it to the frame. Bushings are easy. Pete at FBodyWarehouse over at CamaroClub.net may be able to help me out. Hopefully.
  #243
Old 05-04-2010 | 07:30 PM
Are they the same bracket no matter what bar? If so post me a pic and you can have a set off one of my cars.
  #244
Old 05-04-2010 | 07:50 PM
ATM's Avatar
ATM
I'm sure they are the same. It is for the drop down bars, the sway bar difference in diameter is taken up by the bushing I think.
That is what I need. They don't need to be gold though.
  #245
Old 05-04-2010 | 07:59 PM
Same as the sway bar I'll be out there friday. But there free.
  #246
Old 05-04-2010 | 08:11 PM
The patch looks great! I use self tappers all the time for patches. I know the big time guys use those special clamps, but I don't care for them as they require a pretty good sized hole to fill.
My rear swaybar is from a '79 TA and it's 7/8". My stock front is 1" for a BB engine car.
  #247
Old 05-04-2010 | 08:18 PM
kyphur's Avatar
I've always heard you have to match swaybars to each other. Not necessarily like a 1 inch front = 1 inch back or anything like that but that if they don't work with each other you could oversteer/understeer in turns from mis-matched setups. There's a couple of roadcourse people on the local forum I go to and I could've sworn they said that.
ATM> If Nomad doesn't hook you up with the brackets I think I might have them. I had a full setup from a 78 Trans Am but I sold the bar and struts for it. I think I still have the brackets for it though and if you need them I'll double check and see if I still have them.
  #248
Old 05-04-2010 | 08:32 PM
[QUOTE=kyphur;421324]I've always heard you have to match swaybars to each other. Not necessarily like a 1 inch front = 1 inch back or anything like that but that if they don't work with each other you could oversteer/understeer in turns from mis-matched setups. There's a couple of roadcourse people on the local forum I go to and I could've sworn they said that.
QUOTE]
I think you're correct. Swaybars need to work as a set, but what determines the set size? There's things like shocks, weight additions, springs, engine size. Lots of variables to determine, and unless you're really into that it's a guessing game. I've always used the rule of thumb that the front always needs to be larger than the rear, but not by more than 1/4". Had a friend who did autocross and he told me that was what they did. Made sense, as I've never seen a rear larger than the front.
But I've seen many, many cars without a rear swaybar, so I don't think the "matching" thing is really correct. It's more important to keep the rear smaller.
  #249
Old 05-04-2010 | 09:01 PM
You might be right. The ones i bought are 1 1/8 front and 7/8 rear. The front springs are over 600# though.
  #250
Old 05-04-2010 | 09:05 PM
kyphur's Avatar
Yeah, but almost all the ones I've seen missing the rear swaybar are usually the ones that only care about going in a straight line.
