Run light out.
Old Mar 25, 2021 | 01:18 PM
WayneJackson's Avatar
Default Run light out.
Front running light is out on 1 side TS works swapped bulb still no light the bulb is loose and i have Bat. Voltage at spring loaded piece that touches the bulb could the socket just be so loose that the housing is not contacting to make ground. I was considering just installing the LED replacement set up for the front and back lights had anyone donethis before or am i just going to run into issues with these products that say they are actually made first the car?
KJW468
Feb 7, 2013 09:30 AM
Big Zeus08
Oct 9, 2012 11:05 AM
96 3.8L Texas
Mar 4, 2011 05:15 PM
Stas
Aug 11, 2007 08:03 PM
lowmileage
Aug 10, 2007 11:43 AM
