Turn signal help needed
Old Apr 11, 2026 | 07:18 PM
AdamS79's Avatar
Default Turn signal help needed
Trying to put a 79 back together.
New turn signal switch in steering column.
Hazards work fine.
Turn signals do not.
All fuses are good.
Out of back of turn signal relay are three wires. 2 pink and one purple. If I splice in 12 volts on purple... the turn signal lights come on with the turn signal lever...but don't not flash.
RRelay is also new.
Anyone know what I'm missing?
Thanks in advance.
A
Old Apr 13, 2026 | 04:43 PM
does the 79 have separate flashers for four ways and blinkers.
Old Apr 14, 2026 | 06:24 AM
AdamS79's Avatar
Yes.
i believe the hazard blinker relay is the one in the fuse panel while the turn signal relay is wired in the harness near the fuse panel.
I have replaced both.
Old Apr 15, 2026 | 04:25 PM
best to find a factory service manual.
newtoy78z28
May 15, 2022 02:20 PM
Dj Aztek
Apr 8, 2010 10:27 PM
robs93z28
Aug 23, 2009 11:09 AM
dustinb
May 1, 2008 06:27 PM
bluebike2000
Aug 19, 2006 07:51 PM
