turn signal
Old May 13, 2022 | 04:19 PM
newtoy78z28's Avatar
Default turn signal
I have replaced turn signal mechanism in steering column replaced rely at fuse panel, replaced flasher relay and when I turn on right side flshers come on, turn on left side and turn signal and side marker work up front but in back just rear bulb no side marker. Everything has been working fine until all of a sudden. Any suggestions? Thanks
Sorry 1978 camaro z28
Old May 13, 2022 | 08:43 PM
red42's Avatar
Default turn signal
Newtoy,
I would swap all of the rear bulbs, left for right, to make sure all of the bulbs are good.
Look for corrosion in each bulb socket, and on each bulb. Replace the crusty bulbs. Replacement tail light sockets are available at auto parts stores, if needed.
Find the ground wires for the tail light sockets, and run a dedicated ground wire from a bare-metal ground to splice into one or more of the socket ground wires.
Corroded grounds and sockets are a common cause of tail light malfunctions.
Keep us posted
Old May 15, 2022 | 11:14 AM
Default Turn signals
Originally Posted by red42
Newtoy,
Keep us posted
Not really sure what I did but all signals work correctly. Removed all bulbs in rear signals and replaced with correct bulbs and cleaned sockets cause they were packed full of electrical putty and don't know how any bulbs were making any type of contact.
Old May 15, 2022 | 02:20 PM
red42's Avatar
Default turn signal
Newtoy,
Corrosion is the most common cause of light failures, even in newer cars. Removing and replacing a bulb can break through the corrosion, and expose fresh metal to make contact. Insulating grease is intended to prevent the corrosion, but as you have seen, sometimes it just hides the problem. Clean sockets and bulbs are the way to go, for me.
Now and then, come nightfall, I take a run to a strip mall, or any place with large glass windows facing the street. I stop where I can see my lights reflecting in the glass, and check that everything works as it should. Most often, a problem will be solved by cleaning a corroded socket or bulb, or fixing a corroded ground connection between the sockets and chassis ground.
dsours69RS
67-69 I6 Tech
Aug 18, 2021 11:31 PM
H2C
Mar 12, 2011 05:15 PM
Dj Aztek
Apr 8, 2010 10:27 PM
Gmed1990
Nov 17, 2009 12:56 PM
robs93z28
Aug 23, 2009 11:09 AM
