Tranny?
Old Aug 19, 2010 | 11:48 AM
CaMaRo55's Avatar
Smile Tranny?
i was wondering if anyone can throw some ideas my way for a good 5 speed transmission? my motor is a small block 400 pushing about 425HP and 450 tourqe. Any imput is greatly appreciated. Thank You
Old Aug 19, 2010 | 01:31 PM
jason7504's Avatar
you can get a t56 or tko500. i would do tko500 if you can
Old Aug 19, 2010 | 02:41 PM
Depending on your rear gears. Tko500/TKO600. Shorter (higher numaricly) gears will work better with the first gear in the 600. The 500 works with around 3.23-3.42 area. Hurst driveline recommened a 600 for mine w/3.73s. Give them a call they know more than I do.
Old Aug 19, 2010 | 02:57 PM
kyphur's Avatar
The stock 5 speeds are known for tearing up behind high torque applications. The T-56 has a torque rating of up to 450 ft/lbs and have been known to handle more in their stock configuration.
Old Aug 19, 2010 | 06:10 PM
I'd look on Craigslist for T56 5 spd. if money is a concern, but if not go with one of the TKO's.
WIspartan1026
Mar 25, 2010 09:58 PM
bhoeksema
Mar 6, 2010 08:38 PM
blowncamaro
Oct 12, 2009 09:05 PM
rancheronut
Jul 14, 2009 01:12 AM
mpd228
May 11, 2009 09:52 PM
