tire recommendations for my '80 Camaro
Hi Folks,
Can you recommend tires for my '80 Camaro? I currently have Dunlop SP 40s on there, size P205/75R14. The engine is a V6, 229, 3.8.
I'm a bit of a novice when it comes to buying tires. The Dunlops seemed to work fine, but I've scuffed one of them up pretty badly and figure I should just replace the whole set. I want to get something that handles well in all weather. Am I limited to the 205 size? I like the looks of some BF Goodrichs, but they may be too large.
Thanks,
Mike
Thanks,
Mike
dont mean to hijack the thread but no sense in posting another thread when this is close to what im asking..but what would be a good tire size for my '81 camaro? its my daily driver so i dont want too big of tires but i also want that cool wider tire look lol
got any suggestions?
first off i work at discount tire and i also use to have the same tire size 205 75 14. their really isnt much of a choice due to not much takes that size but older cars i would recommend that you upgrade your wheel size so you have a better choice in different andbetter quality tires
Man, some one asks about tires and they get answer right away, I'm looking for advice on the best way to spend $10,000.00 on restoring a 80 rally sport and I get nothing. Sorry, by the way I would go with STix80's recommendation. He is right abouit the older car smaller tire issue
If you go big in the rear make sure you are 100% sure of the backspacing you will need to get your clearances. I've never seen a place that will let you return tires once they've been mounted.
