Spring for fuel filter
Old Dec 21, 2011 | 09:57 AM
Jacky Chevy's Avatar
Default Spring for fuel filter
Does anyone know where to get a replacement spring for the fuel filter?
I can't find it anywhere online and if they have it in their catalog and you want to order it they say discontinued or out of stock.
Old Jan 15, 2012 | 03:00 PM
camaros4evr's Avatar
I'm guessing you have a carb on this car, if so, its probably a Q jet, try checking out Edelbrock's catalog. or Year One, or Classic Industries, probably have to buy a carb rebuild kit, should be included. Good luck.
Old Jan 15, 2012 | 07:33 PM
Go to a hardware store that carries small spring kits or individual springs. Any lightweight spring that's about 3/8" diameter, and cut to about 1/2" long will work fine to hold that sintered bronze filter.
I always toss those filters away, and put a quality inline ahead of the carb. Those things are junk.
Old Jan 15, 2012 | 08:56 PM
What 71 said about the spring, all you need is tension to keep the filter against the front fitting (spring goes in before the filter). Oh, and unless someone swapped an older carb onto your engine, yours with the long inlet horn takes a long style paper filament filter, not the shorty bronze one. Parts is parts: Rochester Carb / Quadrajet Parts Page
Old Jan 17, 2012 | 12:45 AM
Thanks for the reply...it's a dualjet and I already have the filter...non of the named stores has the spring anymore.
Found a few springs that could fit but also wondered about the right length so it will sit right! Thanks 1971BB427 for the hint regarding size.
I found the spring in a rochester online store but need to buy more there. I will go with the inline I have now until I rebuild the carb during the summer.
Thanks again guys!
Old Jan 17, 2012 | 02:01 AM
I would have just put a cheap plastic filter on it.
Old Jan 17, 2012 | 11:17 AM
5time F's Avatar
When You rebuild the Qjet make sure you Epoxy the secondary Metering wells... if they leak you will never get the carb to tune right and it will always run rich.
Old Jan 17, 2012 | 11:41 AM
He has a Dualjet (2 barrel).
If you're going to install an inline filter, then maybe keep it that way and forget about the in-carb filter altogether. I never cared for them anyway, for their small size/filtering capacity. Also, in my opinion, if you value your car I wouldn't use one of those cheap plastic inline filters. Use a steel one, it's safer since it won't leak from getting brittle and cracking, or melting if too close to an extreme heat source.
Old Jan 17, 2012 | 01:18 PM
True, I haven't had an issue. I was just trying to steer him away from the ever so shiny glass and chrome ones that are certain to leak at some point. My Camaro has the old school Fram canister and a steel mess prefilter for what its worth.
Old Jan 20, 2012 | 09:03 PM
jeff 1980's Avatar
about the arm rest i saw a pair for sale on ebay they looked in good condition check it out
superbowen1
Nov 7, 2011 01:56 PM
jon_uscg2001
Aug 25, 2011 12:23 AM
4g63t
Jun 20, 2011 06:25 PM
johnson3034
May 25, 2007 09:35 PM
SoCenSSCamaro
LS Series Tech
Oct 1, 2006 03:58 AM
