removing my 79's speedo cable
Old Nov 3, 2008 | 11:23 PM
David56's Avatar
Default removing my 79's speedo cable
i took my camaro to my auto shop at school and couldn't quite detach the cable from the back of the cluster how do you pull it off? pictures would REALLY help
Old Nov 3, 2008 | 11:52 PM
Default RE: removing my 79's speedo cable
Look for this type of spring clip: Speedo Cable Clip that will be around the speedo cable housing. Just push the tab down against the cluster, and pull the cable out.
Old Nov 4, 2008 | 12:22 AM
74454bb's Avatar
May 2007 ROTM
yeah unscrewing it doesnt work at all
Old Nov 4, 2008 | 09:23 PM
David56's Avatar
its that easy? i tired that a few times i guess i just didn't push it down hard enough thank you though
Old Nov 11, 2008 | 04:05 PM
bowtieguy's Avatar
July 2009 ROTM
ORIGINAL: 74454bb
long winded isnt it ...lol
Old Nov 11, 2008 | 08:42 PM
David56's Avatar
i took it off and poured a little oil in there hoping it would stop bouncing but it didn't solve the problem but it did help
Old Nov 11, 2008 | 10:41 PM
Take it back off, pull the inner cable out of the housing, clean it off with a good solvent (brake cleaner), and lube it back up with a graphite-based speedo cable lubricant. Oil is the last thing you want to use on a speedo cable, and it will actually cause a needle to bounce.
Old Nov 11, 2008 | 11:10 PM
David56's Avatar
graphite based oil? ok thanks!
mikes68
Apr 27, 2014 01:12 PM
Heathcamaro
Jul 6, 2011 05:51 PM
cbuss54
Oct 9, 2009 09:45 PM
HOTROD MOMMA
Apr 4, 2008 09:19 AM
microkid
Feb 19, 2007 01:52 AM
