rearend question
Old 04-14-2010, 04:38 PM
Originally Posted by Tom071
now ad additional question, i have never worked on a rear end before, is changing the gears and adding a limited slip something i could do myself?
Ditto what ATM said! Not only very precise work, but I've had it done by people who said they could do it, and screwed it up. Tried it myself once too, but gave up and just pulled it out and took it to a shop. Make sure you take it to a shop that only does rearends, not just any shop.
I also agree with ATM on the first response; just buy a good used posi rearend. Tons cheaper! Gears with cost you a couple hundred, and probably that much more for installation and setup. For under $400 you can get a complete 10 bolt posi.
Old 04-14-2010, 10:01 PM
Tom071's Avatar
once again guys thanks for the great advice
Old 04-14-2010, 10:06 PM
Tom071's Avatar
not good the closest one to me on craigs is 150 miles and is $1200, the hunt continues
Old 04-14-2010, 10:33 PM
I'd check every day and be patient! It may take a month of looking, but they come up occasionally.
Old 04-15-2010, 06:53 AM
ATM's Avatar
ATM
ATM is offline
That is what I do. I check morning and night. I use Craiglook.com though, I created an account, and you can save searches now, it will search a radius around your zipcode rather than changing to different towns in Craigslist. Much more streamlined.
mick.mcgirr
01-01-2011 02:36 AM
1quik4
10-31-2010 08:49 AM
JeepGuy12
01-01-2010 11:59 AM
77LT107
02-13-2008 03:04 PM
2000Z28
LS Series Tech
04-07-2006 02:10 AM
Quick Reply: rearend question
